Sony Xperia E Dual - R2R Client problem
VaTo7
My Xperia E is working properly,but there is one problem - in android topbar there is written pending for sim 2.I read app info and it is created by the programm - R2R client.
how can i fix this ? or does my phone need something ?
13 REPLIES 13
Vengence
check your sim ...try other sim
401
My Xperia S is not downloading Internet & MMS setting? I changed the two sim card of another company, but the problem is not solving, so I hope you will give me a better solution??
ganu
MY MOBILE NOT CONNECT DUE TO R2R CLIENT HAS STOPPED
Jelox
What is the meaning of r2r client has stopped
kozoni94
Imhaving the exact same problem on my Sony Xperia Z3 Compact. Could you send me an email if you get a reply from sony?  It would be much appreciated.
kozoni94
Are you having problems connecting to your network? Like to use your data and call people?
Apraes
how you solved your problem with downloading Internet & MMS setting ?
 how you solved your problem with downloading internt & mms setting?
Mr_P_Penguin
Hey there, I'm not so much experienced with this stiff but I'm pretty sure that's a network/human error? Unless like me you couldn't find the extension to make your sim card bigger? I've even gone through the effort of getting a screen shot from my network of the human error (meaning you forgot to do something, I just don't want to be rude about itScreenshot_2017-08-06-09-38-48.png
ag58
I have Sony Xperia phone. It is working good but when internet open proble rise " R2R client stopped. I hve chaned sim also but problem still persist.
