I have a Sony KE-48A9 connected to a Humax Aura box after getting rid of Sky Q, I needed a box that can record more than 1 channel at a time. On the whole I do love the Humax box, but I really want to just use my Sony remote rather than having to constantly switch between the Sony TV remote and the Humax remote.
I have managed to setup the Set Top Box on the Sony TV settings and find the Humax box. And for the most part the Sony remote works perfectly well, you can change the channel, volume, access the guide etc. The MAIN issue is that I cannot map the 'Recordings button' to the Sony remote, which means that you cannot access any of the recordings on the box without pressing this on the Humax remote and therefore I am still tethered to using both remotes.
Does anyone have any tips on what else I could do to get around this so I can ditch having to use both remotes and just use the Sony one. I have added a photo of both to see as an image of the buttons that need mapping IMG_0699.JPG
Hey there,
The recording button on the Sony remote will not work with your Humax box, as this button is mainly there for recording through the TV itself using an external HDD, not using an external TV box, so I think you won't be able to setup these 2 functions together as they're completely different.
Cheers.
