Sony Ps lx310bt power issue?
Hello.  Ive owned this turntable for 15 months, just over my warranty period.  Today I've been listening to records when the player suddenly stopped.  Upon lifting the platter, I've found that the belt had slipped off.  I have reattached, but now there doesn't seem to be any power going to the unit.  The led light which indicates the power being on (orange) and when connected to Bluetooth speakers (blue) isn't showing at all now.  Have been googlin all afternoon but can't find any solution......  can anyone help? Thanks
3 REPLIES 3
Joe_Dohn
Specialist
You should try using a different wall socket and make sure the cable is connected properly, but if there's still nothing after that, you should probably reach out to the Sony support reps as it might need repairing.
profile.country.RS.title
uthnrh
  • Standard driver software is supported. No installation of dedicated driver software is required.
  • Operation with all computers isn't guaranteed.
  • The following operating environments may prevent your turntable from operating normally:
    • Home-built computer
    • Computer with a user-upgraded OS
    • Multi-boot computer
    • If the sleep, standby, system suspend, or power-saving features are enabled.
  • Some recording software titles offer input playthrough or a similar setting that allows you to send the audio to your computer's speakers or headphone jack while you are recording. Refer the software manual for more information.
want 82 tv mount? visit https://wallmountedhub.com/best-wall-mounts-for-82-inch-tv/
Unrthdx
Hey Dekwhitton, did you ever fix this issue? Mine has done the exact same today (Looks like I'm going into 2023 without a player!?) Any info would be appreciated :slight_smile:
