- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
BDP-S490 HDMI output to projector doesn't work
Newly purchased BDP-S490 works well when connected to TV via HDMI.
But when I connect it to my Panasonic PT-AE7000 projector, I can see the bluray logo when powering the player on but after, the home screen does not display.
At that point the projector turns back to its blue blank screen. Seems like it can't cope with the bluray players home screen format.
This is strange as I have no problem using my PS3 or any other device. This is a recent projector that handles most formats well.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
Hmm strange, make sure you have updated the firmware on the Blu-ray player and maybe also try a different HDMI cable, so you can try and identify where the issue lies.. Its almost like the projector is trying to display a signal that is out of range - much like on a PC if you tried to display a singal that was beyond the resolution of the screen to display. It would flicker and go blank. Have you reset the projector to factory settings?
Thanks
