BDV-N7200W USB Keyboard (pref wireless)
bigmac67
Hi
I just bought this Blu-ray home theatre system, so far very happy with it except for the remote control on-screen keyboard which is completely awful.
I tried plugging in both my wireless Logitech keyboards and both report that they are unsupported. Can anyone point me to a cheap keyboard that they know is supported?
I searched and only found a couple of folk asking similar questions 3-4 years ago, neither of which had definitive answers. With all the online services provided these days someone must be using a keyboard, just searching BBC iPlayer and putting my Spotify user name in was so painful.
thanks for any help.
Tags (3)
1 REPLY 1
Anonymous
Not applicable
Hi there
It appears only wired usb keyboards are supported.  If you install sonys TV SideView app on a smart phone or tablet, you should be able to use the remote control functions and most probably text input.
Thats the only thing i can suggest im afraid.
