Sony DAV-DZ260 strange behaviour - no sound on radio
calinro
Althrough all other functions works fine, with perfect sound, when I switch to FM or AM Tuner, it remains silent. Only a very low noise in the speakers, as like no source connected.
On FM it says "tuned stereo" on all the presets, but no sound at all. I havent moved any antenna/ position/ speakers. It just stayed unplugged for like a year, but all the presets are as usual. No change using auto-tune. It remains silent.
On dvd/ cd/ aux it works like a charm... Sound is as it should be.
Anyone has an ideea what happened? Please help!
3 REPLIES 3
calinro
I forgot to say that RDS is working fine, so is not a reception problem.
calinro
No one has a clue??
Anonymous
Not applicable
Hi calinro, Sorry to hear you're having issues with your device. If you can't get any answers from the Community, perhaps try getting in contact with Support? You can use this form: http://bit.ly/1tD6A0w
