sony srs-zr7
kynol123
sony srs-zr7
Any idea for wall or ceiling mounting brackers for the sony SRS-zr7 speakers.
Also can this speaker work fine with not horizontal position ?
Thanking all in advance.
4 REPLIES 4
Pascale_F
Moderator
Hi kynol123,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Almou_10
Specialist
Hi kynol123,
I'd recommend installing the speakers horizontally as Sony recommended so in the help guide in this link: https://bit.ly/2mlLS5P.
As for the wall mount bracket, I couldn't find one as it says it's being sold locally. I've looked it up and it seems that it's just two pieces of metals L or C shaped that get's attached to the speaker first then on the wall. Maybe you can check with a local dealer?
Hope this helps,
Almou_10
kynol123
Hi  Almou_10,
Thank you for your quick response.
You mentioned taht as the sony recomendation speakears need to be installing horizontally but would they work fine  fixed horizontally and only the face be directed downwards as it wold be requied when I put them close to my ceiling.
Thanking you in advance
Almou_10
Specialist
Hi kynol123,
I don't see a reason why it wouldn't work. However, I'd take Sony's recommendations into my consideration if it was me.
Cheers,
Almou_10
