Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I suggest that you take a look at the user guide for Xperia M2. Check page 7 at the following link and you'll find info about how to insert the SIM-card:
http://www-support-downloads.sonymobile.com/d2303/userguide_EN_D2303-D2305-D2306_1_Android4.3.pdf
Check out this pic:
Anytime.
Hello community
I bought my phone in Chile use it with Virgin Mobile company. The following week trip to Argentina with another sim and the system was upgraded with Sony Companion but upon returning to Chile sim no longer recognizes the Xperia M2 therefore I do not have the apn enabled
my five cents on the sim slot
i am a 50+ and i did not see that there is a dummy sim inside if you buy phone - i was trying several times to insert the micro sim before i checked it out that there is already a little black already inside
would be a great help to figure that out in the quick start manual
Thanks
My Sony m2 comes up saying no sim no service even with the sim card in it
