Call history/log is not showing up
ktick
I made a call from the call history (to a last called number) and then locked the screen from there. Then when I unlocked the screen, I am not seeing the call history atall !!! Its showing blank, I tried to restart and make calls, etc. but still the history shows empty. Anybody else faced this issue ? Any known workarounds ?
This is a big problem as call logs are very important feature for me as a basic phone itself. Please give your suggestions.
33 REPLIES 33
Nabeel
Master
Go to dialer > press menu button > show call log
RoDaTo
Z1 not showing call logs, tried portrait, landscape, all possible settings combinations, nothing...transferred phonebook from Xperia Ray...Contacts+ does the job...
kinky
thanks Nebel... u made my day
for xperia U users you can go to dailer n den press the extreme right point down on the phone n hold it for 2 secs den then the "show call log" option  pops out. click it and enjoy...
Benja
Hi, I bought last week Xperia Z1 Compact on Android 4.3.
My log is not showing and I defintely have the option (from bottom right) as "Show Call Log" on.
Call log is still not showing, I have restarted my phone several times and still have blank page.
If anyone has a solution as this very annoying and can't find advice anywhere.
Thanks!!
profile.country.RO.title
_alexdon_
This is Xperia P section.Try and remove the micro SIM and put it back in.Also,restart your phone.
alexdon
love1st
Having the same problem even after trying suggestions on here
_alexdon_
Have you checked if it is not hidden?
alexdon
Zaks
Hi Im having the some problem ....did you manage to solve it ....apple you just dont have these problems very frustrating !
_alexdon_
Check if they are hidden.Also,try settings-apps-all-phone,force stop and clear data.
alexdon
