Hi, Does anyone know how to give static ip to wifi of sony tipo dual. ? or any android application which can help me to give static IP
mayankthareja
sudharsanan
hello,u will go to settings and click wifi and u will scan wifi network and u r long press on wifi range , u got a messege forget network or modify network u will click modify network and u r tick advance option
u got the ip settings and u will change the option dhcp or static..
5 REPLIES 5
Sam
Legend
Legend
You could try Wifi static from the Playstore:
https://play.google.com/store/apps/details?id=com.farproc.wifi.statIc&feature=search_result#?t=W251b...
What are your thoughts about this forum? Let us know by doing this short survey.
sudharsanan
mayankthareja
Thanks sudharsanan !! That was the option I was actually looking for. Actually I also have samsung and it directly shows the option to put static IP in the wifi setting that I could not find in sony tipo yesterday.
Anyways thanks for ur support !! Slightly_smiling_Face
mayankthareja
Thanks for ur support. I got the correct answer from other person. Thanks for your concern.!! Slightly_smiling_Face
Tiffany1
Hi
I have the same problem.  But my phone isint allowing me to save the static ip option. Should I alter any of the digits in the fields?
