How to get in a FB post as sent through Sony Xperia Smartphones
monalisap
Hi, I have noticed many people when they do a status update through their sony phone it shows as sent through sony xperia smartphones.. I am unable to do that. when i use the FB application from the phone, it just says sent through mobile..Can anyone help me out with this ??
FYI: I have activated the integration feature as well but still no use.
bluechip850
goto Timescape,
get FB signed in.. right soft key, set update status.. Slightly_smiling_Face
hope that helps..
6 REPLIES 6
bluechip850
goto Timescape,
hope that helps..
Petter
Enthusiast
Thanks for posting and welcome to the forum!
Correct what bluechip850 states. Make sure to use Timescape and it's posted as from your Sony phone. Slightly_smiling_Face
What do you think about this forum? Let us know by doing this short survey.
monalisap
Thanks a ton Slightly_smiling_Face
bluechip850
you are most welcome...:smileyhappy:
n00BXperia
its not working..unable to install thin Xperia M .Single SIM version..HELP!!!
engrblue
how to go to timescape?
