How to tell if xperia phone is fake?
mwake
Just ordered my xperia phone on ebay and i'm waiting for it, i decided to go and check the feedback score last night and saw that some people were saying that there phones look like fakes...
How would i be able to DEFINITIVELY highlight if my xperia pro was fake?  What are the blatant signs to look out for? What are the genuine SE makings that wouldnt appear on a fake phone?
If anybody knows the answer to these questions please let me know....
Uliwooly
if 1 and 2 work it will increase the possibility to be real. if SUS works it shouldn't be fake
Don't forget to mark the Correct Answers & Helpful Answers
14 REPLIES 14
Uliwooly
try to run SUS and update the phone or try to run track ID or contact any Sony Moderator with your IMEI number so they can double check
mwake
Thankyou for quick reply. some more questions
1) So TrackID doesnt work properly on fake phones?
2) Also if PC Companion recognises the phone, does that increase the possibility of it being a genuine product?
thnaks
Uliwooly
mwake
Couldn't be bothered with the hassle of theses third party sellers and cancelled the order...was reading through the feedback and seeing people being delivered phones that looked refurbished even thought the advert says brand new!
Played it safe and bought from the Sony website itself, and in the end it was only £20 more expensive..
My advice for anyone trying to buy from third party sellers on Amazon, Play.com and Ebay is beware!!
Thanks for your help anyway Slightly_smiling_Face
Uliwooly
Anytime
Stanman
I'm currently using a Xperia Miro and want to upgrade to a Xperia V. Today I had a look at some of the ones in a shop. I remember reading online that the Xperia V has a 13MP camera. I had a look at the camera of one the ones I saw on offer and it seemed to have 12MP instead. Everything else seemed to be as the original though. I forgot to check the memory however. But is it possible that there's a version of the Xperia V with 12MP?
profile.country.RO.title
_alexdon_
Use the manual mode of the camera.
alexdon
ran93
What is SUS??,, this is my first time using Sony,,I was expecting that the camera is good,, but it's **bleep**, , so how can I check if my Sony is ori or not??1
Thommo
At the time of this thread been made SUS is Sony update service however as of 21st July 2014 that service has been removed and is no longer available for download
You could type your IMEI number in to this site and it will tell you the make and model - If it's fake the then you shouldn't be given the information pertaining to your phone http://www.imei.info/
