My Xperia t can't connect to the PC via USB cable.
Changazi
Xperia t can't connect to PC via USB cable,
Again and again LED light blinks and connected and disconnected then my cell restarts.
I have changed USB cable, connect to other Laptops and computers but same result.
Neither I have root or flash my Xperia t...... Please help me.
Alexander1
Champion
Download and install PC Companion from our website:
http://www.sonymobile.com/update
If you already have it installed on your PC, you can try to reinstall the program.
Also check the following FAQ topic for more information:
http://talk.sonymobile.com/t5/FAQ/USB-connection-problems/m-p/348074#U348074
16 REPLIES 16
basil45
basil45
My pc says I need device drivers & to get help from sony help
Alexander1
Champion
Changazi
Really thank ful to your help....
rassouljah
There are a couple of problems with my xperia T the most prominent and annoying 1 is everytime i switch it off it losses track of time. and i can access it without entering a pin or password even though they are activated... It can not connect to USB and iv tried all the methods you listed
mary1231
hi , i have sony xpeia u and my phone doesnt connect with  my laptop....i dont know what to do ....any solution ?? thank you very much
india5
dear sir i try lot of time to connect my xperia to my pc laptop & office pc,but i have problem with connectiviti.
my phone usb dubbing mode is on . in divice only show light but in pc not show sd memory or divice memry mand i chang data cable 2 other try to connect .and my mobile factory reset by all methods .i instolled sony combenion which work properly other sony divice,
please give me proper solution,thank you!
omyno4real
hi my sony xperia U  will not connect to my pc (XPERIA COMPANION) its charging but sony companion will not detect my device
blondemumma93
I also have this problem! I have tried other phones, other usb cables and nothing is working!
My phone connected fine a few weeks ago but since then I have had an update on my laptop (not sure if this is anything to do with it?!)
My laptop recognises my phone when it's in charge mode, but when I change to transfer files nothing happens.
Also tried device manager and updating driver but apparently I have no driver thingy on here 😕
I have the Xperia companion which also doesn't detect my phone while plugged in!
Any help would be greatly appreciated Slightly_smiling_Face
