Hi all,
My experia e5603 had its smaller (phone call) speaker at the top of unit; go down today - 19 Oct 2016...
this is really poor on SONY's part; how many years, according to this site has this issue been going on for???
Good grief.
Have been trying some of the suggestions, but no luck so far. if I have to go back to SONY I'll NOT be impressed.
Useless junk! It's less than 6 months old.
Like others on here, I can put the phone on loud speaker (and lose confidentiality), or use headphones.
Again... how poor is this!
Hacked off in Bolsover Castle (Derbyshire).
does it work on you? the safe mode? it did not work in me.
From the Google play store download app called sound about, select media then speaker, then select phone call then earpiece, and back out of app and its fixed i had to do it twice and then it worked like a charm. I cant believe this is a software issue sony has never put up a software fix for shame on sony. All i did was youtube it and bam followed directions and it was fixed
I have the same problem. No ringer, no sound but headphones and mic work and a portable speaker. I tried talking the headphones in and out but didn't work.
After i dropped my phone the speaker won't work but when i plugged my earphones it works how can i fix it?
This worked for me too! 🙂 Thankyou
I Logged in just to say THANK YOU SIR! Im using Xperia Z1 and pressing around the bottom of my phone works wonders!
No sound from speakee
