Packet Data not working to my Xperia S (LT26i) Handset
repon
I bought Sony Xperia S (LT26i) handset two weeks ago. I'm from Bangladesh and my network provider is GrameenPhone (2G). I configured APN setting manulaly. But It not working. I thought that it was configuration problem. I went to our customer point for resolving this problem. They checked all settings and told me all settings right. But when I am going to browse website then browser show 'no connection'.
Please review my setting:
Data Enable = yes (mark)
APN: gpinternet
MCC: 470
MNC: 01
APN type: default, supl (also tried to internet and not set)
and all other settings are default (Not set)
Network Mode: GSM only (also tried to WCDMA(preferred)/GSM)
Finally I selected this APN and restarted my handset. But It is not working.
Please Please Please Please help me.
I am being very disappointed and I am very tired.
Thanks,
Repon Hossain
Uliwooly
to start with 2G it's quite slow and perhaps you are not using a micro SIM card but a trimmed SIM card? also check your network's coverage (settings > about phone > status> signal strength
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
Don't forget to mark the Correct Answers & Helpful Answers
UNRELATED topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
4 REPLIES 4
Uliwooly
repon
Thank you for your quick response.
Yes - you are absolutely right. I don't use micro SIM but I use trimmed SIM card.
I went to my friend who use Sony Xperia P. He use packet data internet without any problem. I took his SIM card and put it in my Sony Xperia S handset. After turning on my handset packet data is working good.
Thank you again uliwooly.
I am now happy.
Uliwooly
anytime Slightly_smiling_Face
GOBIT
I always have this problem when I insert a new sim card.
Solution
first of all : Not forget that the mobile data should be enabled.
than
Go Settings > Xperia > Internet settings (Download settings for internet and MMS)
