random pausing of games in jb?
dp10
hey why is my games just randomly pausing while playing??
im running on JB ?
can sum1 plz help?
games like subway surfers temple run etc? even after a service update?
Samuel1
Hero
Are the games actually put on pause or does the game hang/freeze? If it hang/freezes it might be due to high RAM usage in the phone.
13 REPLIES 13
Samuel1
Hero
dp10
its actually pauses while playing randomly ...nd der is also a freeze in d game Slightly_frowning_Face ...does dis mean i cant play games any more on my phone Slightly_frowning_Face
Samuel1
Hero
Did you reset the phone after the update? If not, you should try it.
dp10
how do i do it? ... and wad about  my files and all the stuff stored?
Uliwooly
your pictures, movies, videos, music should not be affected
dp10
thanx for the reply Slightly_smiling_Face anyways hope i can play all the games i used to before all these problems strtd Slightly_smiling_Face
Uliwooly
some games might not work as the developer (game developer not Sony) has to address compatibility issues
hkrocks94
dude!! just uninstall mcafee antivirus , the problem will be solved Slightly_smiling_Face
dp10
HOW DO I UNINNSTALL THAT APP?
