I was playing around with ringtones on my Xperia Go.
Until now, when I went to choose a new ringtone, I was offered the choice of using "Sound picker" or "Android system" to do so.
I have just set "Android system" as the default by ticking the box in the popup, but now I realize it doesn't give the same choices as "Sound picker".
But I can't clear the default setting, when choosing a new ringtone it goes straight to the "Android system" choices without giving me the choice to use "Sound picker".
Usually you can reset this by going into settings->Apps and clearing an App's defaults. But "Android system" isn't listed as an App.
There must be a setting somewhere else. Any idea where?
OK, found it myself.
You have to look under the "All Apps" tab under Settings->Apps.
I have the same problem what do u have to do?
I can't reset the default. I cant press the button Clear Defaults in BOTH Android System and Sound Picker.
When I wanted to select alarm tone only Android System tones are poping out. There is no option of sound picker..
And I cant clear the defaults.
PLs HElp.....
I got it myself friends..
Go to Settings > Apps > All Apps > and click the top right corner one with three dots..
Click it > Reset Preferences Apps > and a window will appear .
Click > Reset Apps
and all will come to normal way as it was new..
THanks Guys ! ! ! !
@Hitesh111008 wrote:I got it myself friends..
Click > Reset Apps
THanks Guys ! ! ! !
Alternatively, if u just want to reset one app, instead of all of them, u can choose Display system apps after clicking the 3 dots and it'll have everythi g your phone uses. This is how I was able to reset my sound picker
kudos. Really helpful
Reseting Android sound picker
Help with this.
