SMS/missed CALLS LED notification...?
zaka
Inadequate work of SMS \ missed Calls LED notification in STAMINA mode... Why?
I don't belive that LED notification drains the battery very much...
And anyway what for make such a "super energy-saving" mode in which it is impossible to see who wrote\rang (you constantly have to unlock the screen to see if missed actions... and in a such way turning on your screen to check if something missed you waste much more energy than waste the LED notification)... Where is the logic???
I understand that turning off the STAMINA mode will resolve our problem with LED notification, but (see attached images) may be it's possible to "ADD (some kind of) APPLICATIONS" to "APPS ACTIVE IN STANDBY list" which resolve this discomfort with LED notification and will allow our LEDs to notify us about missed calls \ SMS even in STAMINA mode?!
Screenshot_2013-06-05-12-18-47.pngScreenshot_2013-06-05-12-18-38.pngScreenshot_2013-06-05-15-40-32.pngScreenshot_2013-06-05-15-40-46.png
How to make sure that the wolves were fed and the sheep were intact?!
In other words: how to make LED notification working in STAMINA mode?
IS IT REALLY SO DIFFICULT? I DO NOT BELIEVE!
If it's imposible - sorry but your STAMINA mode sucks!!!
Sony team BE HUMAN !!!
PLZ!!!
waiting for a clear answer \ advice!
___________
Best regards
14 REPLIES 14
eljunpacomios
UPDATE on MISSED CALLS LED Notifications..
This didn't work for me. for SMS LED notification,
I also tried it on missed calls.. But NO LED Notification on Active Stamina
Mode on the new update, AFAIK.
zaka
Hi, eljunpacomios
I wrote above how to make LED notification working on the new update...
read carefully!
This method works! reed here state 13:
http://forum.xda-developers.com/showthread.php?t=2249341
guide:
all that you needed is to have root rights and install with replacement SuperStamina.apk)
eljunpacomios
Lol. That's another story and I read carefully.. Rooting the phone and other stuff.
I know that already.. What I emphasized was the clean update
not the rooted one.
zaka
in "clean update" in stamina mode LED notification will not work!
forget it!
Smiling_Face_with_Sunglasses
zaka
"i just updated something here and now the led light works on stamina mode"
sounds unconvincing...
After update from 6.2.A.0.400 to 6.2.A.100 with stamina mode enabled LED notification doesn't works!!! 100%
LED notification with stamina mode enabled doesn't works bouth 6.2.A.0.400 & 6.2.A.100.
works only after installation with the replacement SuperStamina.apk.
as wrote above.
