Hi!. i have a problem with my j10i2 phone.I connect the phone to my home wifi (succesful)and then try to log in to my mail adrress for example (but i get the same error on other sites when i try to log in as well) i get this message "Communication failure.Secure connection failed" and i don't know what to do .pls help!
Thank you for asking and responding to this question. I also experienced this problem. This is the only answer available in the web. I first started conduncting my query in spanish and found nothing. The message in spanish is "Error de comunicación; error de conexión segura." Prior to this I was fully able to navigate, yes: I attribute it to https protocol.
El consejo es instalar Opera Mini, lo hice y he vuelto a navegar con normalidad.
Anyhow, I'd like to know what's the preset browser for J10i phones, and whether the company will publish an updated version anytime soon.
on my phone Sony Ericsson elm j10i2 how to enable java ?
If you mean Javascript, the Elm doesn't support it, although this phone is a Java-OS phone, which is a different matter. Hope that clarifies things!
I'm having the same issue, phone worked fine on facebook until yesterday and now all I get is the communication failure message. Tried to install opera but it says not enough storage space even though I formatted the memory card, help please! It used to say it for some sites such as my email but facebook worked fine until now. other sites are still working ok though
Whenever I try to download any stuff it shows me "Operation Failed"
Please help me to solve the problem. Even the opera mini is not installing.
