the Xperia P will upgrade to 4.2 or the 4.1.2 was the last upgrade?
there are other threads on the same topic, for any official info check the official blog, keep away from other blogs such as the verge which like to post rumors as facts and later delete their posts or change it; use the searchbar and type theverge and you will see all the lies they have posted
but anyway there isn't any info a side from the Xperia Z getting 4.2.
ok thanks
4.2? We are still waiting for 4.1 on our XP.
