Voice Recorder doesn't work
michealc
When I try to do a voice recording it won't let me, I even downloaded 3rd party apps and they didn't let me record either! Does anyone know what's wring or what I can do?
michealc
Ok I'll try that now alexdon! Thanks!
13 REPLIES 13
Uliwooly
Could you elaborate?
Do you have get an error?
michealc
I'm sorry but all I know is that when I click on the record button it says 'could not record' , I don't know if it's a problem with just my phone or if anyone else has the same problem! Thanks anyway uliwooly !
profile.country.RO.title
_alexdon_
Try to clear data for voice recorder in settings-apps-all,force stop and restart the phone.
alexdon
michealc
_alexdon_
Waiting for your answer.
alexdon
michealc
It worked alexdon! Thanks a million!!
_alexdon_
You are welcome,my friend.
alexdon
michealc
Whoops accidentally clicked what I said as the solution instead of yours alexdon!:-P
_alexdon_
No problem,I can unmark the solution if needed,but let it that way,it is just for people to see.
alexdon
