WIFI Association Rejected
Balddragon
My wifi wont conects after i upgarde my xperia to 4.3
Plaeseeeeeeeeeeeee help!
16 REPLIES 16
mbwillow
Is there any headway on finding a solution for this? Seems like reverting isn't working for some. Are they fixing all this messiness
in the next upgrade? Sending out a fix? Stopping support for lt30p ' s?
wolla
My xperia t has had this problem for the past week. Tried forgetting connection etc but nothing worked. After a Google search suggested 'Bluetooth WiFi possible conflict" I turned off my Bluetooth And hey presto - WiFi is restored. Hope this helps others with the same problem
Andy555
It worked.The xperia  has 4.3 and was experiencing the 'association rejected' problem. Turning Bluetooth off fixed it
geek_avi
Before resetting your phone to factory defaults, try resetting your modem settings. Assign a new SSID and save changes. Now on your phone go to settings > wi-fi > refresh / scan for your network. Connect . It should work now.
if not, try resetting your phone to factory settings. Don't forget to wipe off your internal storage. After Rebooting the device, follow the above procedure.
good luck. Slightly_smiling_Face
Andrew161
My Bluetooth is never on and it only seems to connect when using otg with a hub with usb WiFi adapter and even then I only get anywhere from 5seconds to 10seconds of internet then the phone crashes and restarts
magdyelfakhrany
After Android update 4.3 9.2 My Sony Xperia TX say "Wi-fi Association Rejected". I tryed change the ISSD name, channel, encriptation, password, factory restart, re-update dowload fix from Sony Companion, everything. Sony, what can I do...?!
jgrocha
Same here, on a Sony Xperia XA (F3111) with Android 7. I have to turn off Bluetooth to have WiFi.
