Is it possible ?
(I really mean *FM* radio, and not 'internet streaming' radio)
Ideally, a recording application that allows you to select the sound source (fm radio, mic, call, internet streaming, etc.) would be perfect, but I didn't find such a thing. Any suggestion ?
and there are loads of app to record fm from the internet
install it!! use it!! post review here!!:-P
yes it works
but why this app was discontinued anyway and how did you get it..??
hey download the application from here
http://www.mediafire.com/?9qx9n1dhdh4x6il
mark sanatm's and my helpful and correct answer so that other users can see the app ok..
told ya...!! lolz.. don't know...but the app is great..!! except the ui..that's too simple..but although it works...I got this app from where I bought my phone ...I bought it from mobilestore...and a the guy who used to take care of SE phones gave me this..!!
aah great it has only 12 hours of recording.. but i think if we cleared data of the app we would have 12 hours again
guess so!! big memory..big recording!!!
well track id is there , if i love any song i just use track id and download the song :smileygrin:
exactly!! but if u dont have data plan or network connection simply record it with the radio moments and then use track id!! I used to do it lot!!:D
hmm ifirst of all i dont listen to radio that much if i listen , i listen at home only and theres wifi connection so no problem
and the first time i used this my mom and dad coudn't believe it
my mom listns to radio all the time , and everytime she wondered which song was this , but with these apps its easy..
