hey.
My xperia phone just got turned off by itself, so when i triet to turn it on again it just vibrated 3 times. and does not goes on.
I've read by the xperia z forum the things you could to with the power on button and the volume buttons, but that doesn't work either.
could anyone help? my phone isnt even 3 months old..
Connect to wall socket,force shutdown:
After 1 hour,turn the phone on normally.
that doesnt work.. i hope it can be fixed...
Connect to wall socket,charge for 1 hour,repair via sony update service:
http://www.sonymobile.com/gb/tools/update-service/
my phone was on for like an half hour, but then it turned itself off.. now its not responding when i push the power/lock button. if i connect my phone to a wall socket, its doing nothing. not even the leds are working..
there isnt a sony centre here in the netherlands...
after charging did you try SUS..if not give it a try...i understand that phone completly goes off..but try SUS
Just follow that link I gave you.
yeah i tried that, but when i put the usb cable in my phone it just vibrates 3 times and thats all..
