xperia v restarts/reboot after using instagram rotation
mariefrance
Hi everyone.. I just experience this problem last week and twice happened..
When I upload a picture in instagram of a portrait picture, my mobile would suddenly turn off and lost of network signal.
Please help me.. Im sorry for my bad english..
I have the latest firmware.
Henke
Have you tried to clear data in the Instagram app?
Go to settings, apps, go to all, open "Instagram" and press "Clear data".
Try again to login.
12 REPLIES 12
Henke
Try again to login.
mariefrance
Hi I didnt try it yet.. I will try it now and will update you soon,
Thank you so much sir..
mariefrance
After I cleared my data on instagram, the problem is gone.. Thank you so much sir.. I will update you if it persists..
mariefrance
   Sir, was the problem caused by my xperia phone or with the app?
Henke
You're welcome! It seems that something went wrong with the Instagram app.
ych23
same reboot happened while using instagram. thought it was just a random reboot. Thx for the solutions.
mariefrance
Hi @ych23.. Im glad that I was not the only who is experiencing this problem.. Im thankful for your feedback.. 🙂
ych23
u are welcome Slightly_smiling_Face btw may I know if your camera HDR and Image stabilizer can be turned on simultaneuosly? because mine cant.
mariefrance
Yes,there is no problem with my camera.. Image stabilizer is on, and hdr.. depending which option should I choose.. But screenshot is always my problem.. Pictures get pixelated after screenshot..
