Bravia KDL-42W705B sound but no picture
mox888
As the title says I have a KDL-42W705B with sound but no picture. We were watching when the picture scrambled...reduced to the top 6 inches of the screen and then disappeared.
There is still a backlight and sound but no picture. Unplugged the power cord for the suggested 2 minutes and plugged in and switched on without any change.
Anymore settings to try or is it call the maintainence man?
Thanks.
Anonymous
Not applicable
Hi there
It does sound like the TV needs a repair.
Its your description which indicates to me that its a hardware fault:
"We were watching when the picture scrambled...reduced to the top 6 inches of the screen and then disappeared."
3 REPLIES 3
Anonymous
Not applicable
Hi there
mox888
Thanks for your reply.
Yes did think that was the likely outcome. Just wanted to cover things I might not have tried.
Bluetoot
Could you get it fixed? Sounds like we are having a similar problem.
