Other methods of TV Bluetooth connection
KDL-50W829B I have read other bluetooth questions in the forums from what I can glean it is clear that the TV does not have Bluetooth connectivity, so why is it in the Menu's?
However is it possible to fit a bluetooth USB dongle to the tv to connect items such as Keyboard and Mouse, the TV does not recognise any type of Bluetooth as is.
1 REPLY 1
Anonymous
Not applicable
Hi there
You can only connect a bluetooth mouse to your TV (to use for web-browsing).  All other bluetooth devices are not supported.
See:
http://pdf.crse.com/manuals/14HE468111/EN/c_gset_bluetooth.html
No even bluetooth headphones are supported - without a bluetooth transmitter, see HERE for details.
Bluetooth USB dongles are not supported on the TV and will not work - as the TV cannot install the required 'drivers' in order for it to work.
