- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
ok, well some models where the cable fits it goes behind a small plastic plate usually held in place by a small screw, you could remove the screw and plate and see if theres a kettle type plug behind it, then you can remove this and feed thru the hole and plug it back in, but this only applies to some models.
failing that its a case of removing the plug, and for that i suggest calling sony support and check that you can without affecting the warranty, personally i cannot se a problem with that.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
you need to be a litle more specific as to your reasoning for this as its likely you will invalidate any warranty messing around with this.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I want to hide the power cable by feeding it through a small hole but I will either have to cut a larger hole to fit the plug through or cut the plug off and re attached the other side unless the power cable can be removed from the back of the KDL-40HX753? I do not want to attempt to remove it pull too hard and break it!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for the help!
