Hello, I want to change the Scene Select but the problem is that I am not using the original remote control and there isn’t a Scene button. I searched in the settings but there is no scene select in the settings. So is there any other way to change the scene select?
Hi there,
Let me look into this for you and will update the thread if I find an answer. In the meantime perhaps another member of the community may be able to help.
Best wishes,
Sean Mc
Hi Greenb0x,
I checked the manual and it seems that the scene select button is actually a shortcut. You still can follow this sequence instead (Home/Settings/Picture/Picture Mode). Let us know if you managed to change it!
Cheers,
Vanilla_
