Sony bravia
Stapo755
Sony bravia
Hi can any one help just had virgin media installed and tv has started turning on and off also keep losing picture and sound sometimes it's ok for hours then it'll start up and be like it for a  couple of hours tried disconnecting the virgin box and connecting sky and everything seems fine so we connected the virgin box to another tv with same hdmi cables and everything is fine. also tried changing hdmi cables and hdmi ports still the same problems so I've got no idea whether it's the tv hdmi cables or virgin box anyone got any ideas
1 REPLY 1
profile.country.RU.title
SonySupportRussia
Stapo755, good afternoon.
For a more productive consultation on this issue, please describe your actions and symptoms of difficulties in as much detail as possible by sending information to info@sony.ru. Be sure to indicate the model of devices that you plan to use with the BRAVIA TV, as well as the model of the TV itself.
We will answer you within 24 hours
