hi I'm trying to find out how to wall mount my tv.
on the specifications it says I need an adapter but it doesn't tell me where to find this, how much or which one.
the tv doesn't appear to have the usual VESA screw holes in the back of the tv and I want to find the relevant adapter and VESA required for my TVs to enable it to be wall mounted.
regards
Hi there
According to Sony's Help page HERE, you will need a VESA adaptor. It can be purchased from:
http://uk.eetgroup.com/i/93420300-Sony-W-M-Vesa-Adapter-Assy
