When i start up the VAIO there is a message to say I don't have the Catayst Control Centre. How can I reinstall on Windows 8. I have upgraded.
Hi Welshlass,
All I can suggest is that you reinstall the Windows 8 AMD Driver: -
http://www.sony.co.uk/support/en/product/VPCJ23S1E_B/downloads/EP0000278172_8149
Hi Welshlass,
