I have a PCV-W1 G desktop which appears to struggle with operating Ubisoft's Farcry.
I have the standard 512mb and wonder if an upgrade would help ?
Any solutions please ?:smileyconfused:
The W1's graphics card is nowhere near handling Far Cry
Its a SiS chipset so no chance for Far Cry.I was gonna say its a double post as well, but I'll resist !!
_________________________________________________________________
VAIOneer
noun
1. a Club VAIO member who is one of the first to do something.
2. a Club VAIO member who helps establish a community.
adj.
Of, relating to, or characteristic of early members: the VAIOneer spirit.
You dont need to add memory,it depends if your graphics card can take it
And also check if you have Direct X 9.
Check the link out below for Sony PCV W1 Updates
Good luck mate:smileyhappy:
http://ciscdb.sel.sony.com/perl/swu-list.pl?template=EN&mdl=PCVW10
Err, the graphics card can;t take it, period.
Thanks chaps !!
Looks like 'Far Cry' is about as close as I will get to playing it !!
Any similar games that can operate on the 'W' series ?
Anything that will run on 32MB graphic ram.
Try something like HALO or UT2003 or other 'lower' spec games and see what you get.
VAIOneer
noun
adj.
