I have a Samsung TV, which has the following ports:
On my old laptop I was able to have a dual-monitor setup with this TV using PC IN port.
However, now I have a Sony Vaio VPCL14S1E, and I was just wondering if it's possible to have a dual-monitor set up, and if so, which port do I use?
Thanks in advance.
I think if you check the specifications of your L14S1E you will find that because it is an all-in-one computer with a large display, all the video connections are inputs. I do not think there is any Video Output.
The only way to connect would be by add ing your TV to your wireless network.
