Sony vaio operating system not found and no vaiocare with assist button....help!
agangelus
Hi
I wonder if someone can help me out? My son's Vaio VPCF23B9E laptop has issues. when you press the power button the Vaio logo appears but then gives message "operating system not found". When we use the assist button nothing happens and it just goes to the same message. I've checked the bios and the Hard Drive is recognised and 1st in the boot order. He doesn't have any recovery disks and when I tried to boot in safe mode F2 again nothing happens.
Would really appreciate some direction with this.
Many thanks in advance
Ali
4 REPLIES 4
Sean_Mc
Moderator
Hi Ali,
I will try find an answer for you. In the meantime perhaps another member of the Community might be able to help.
Best wishes,
Sean Mc
Almou_10
Specialist
Hi agangelus,
I think you'll need to buy the recovery discs so that you can restore the bundled Windows and also rescue the data on your VAIO on an external HDD if needed.
If you could reply with the 15 digits- serial number i might be able to help you locate the compatible recovery discs and where to buy them from.
Cheers,
Almou_10
agangelus
Hi there
Thank you so much. The S/N is: 54147688 0002097
Regards
Ali
Almou_10
Specialist
Hi agangelu,
You can purchase the recovery discs compatible with your VAIO using this link: https://bit.ly/2JQrKH5.
Hope this helps,
Almou_10
