T Series i7 build, battery and fan issues
voxish
I've got some issues with my T-series SVT1312X1ES
1: The battery only lasts about 3hrs or so in normal use - I have energy-saving battery profile enabled.
2: The screen doesn't close properly, not laying flat over the keyboard. Sometimes it does close flush but more often not.
3: The fan is quite noisy and intrusive.
Has anybody else had these problems? In themselves it isn't that big a deal (the machine still works fine) but it's annoying a I've only had the machine for about 4 months - my previous (much cheaper) year old Acer TimelineX looks and works pretty much as it did the day I bought it. Considering this cost nearly £500 more than the Acer I expect much better build quality - it's never been dropped or maltreated, just use it on my commute to London.
2 REPLIES 2
Thalamus.
Champion
Hi Vixish,
As you have a few issues it may be worth discussing them with Vaio support at least then they are on record with Sony..
voxish
Hi Thalamus
Thanks for your input - yes I plan to do that but they close for the weekend. Just wondered if there are any quick fixes or if any of these are known issues.
