Hello,
I'm french, and i have buy recently a VAIO PCG-K115S (he work very good)
But i want to know, the temperature of the processor.....so how to make this task?? or what is the model of motherboard ? For install a monitor.
thanks
disens
I don't know why I'm replying - I'm English
Your question is unclear. Can you repeat in French (repetez en Francais?). Kee-Lo can help or translate for you :smileygrin:
BTW good luck with your next game
Poor Dave needs to move on, look forward not behind my good friend.
As for disens, he's looking for that program that tells you the tempreture of the CPU, which I forget the name of, but I bet the linkmeister knows.
ok, merci a vous 2 d'avoir été si rapide.
Alors en français ma question est : Comment connaitre la temperature du processeur ?ou le modéle de la carte mére??
(afin d'installer un soft de contrôle...)
merci
Thanks Rob, my memory is getting worse...
Yea, thanks Rob and Kee-lo too. This little soft work right...:smileycool:
Because the weather in france be transform in "canicule".......:smileygrin:
Thanks again
Ouais il fait chaud partout, 24 au Nord Ouest !
Canicule is like weather that gets hotter by the day.
Ha! aujourdhui il y a du vent
c'est mieux pour la ventilation de mon notebook
Ce qui donne 20 ° a l'ombre, et 47° pour le processeur :smileygrin:
Un peu de nuage.
Pluie en prévision.
Voila pour le post météo de la semaine, bon week-end.:smileycool:
Ouais, ici il ya 18, c'est deja mieux :smileygrin:
Bon Weekend
