VAIO PCG-7R1M not booting up and making beeping noise
ljc19630
Hi guys,
I have a 6 year old Vaio thats decided it doesnt want to boot up. When I try the screen stays black and all its doing is making a strange beeping noise?
Anyone got any ideas how to fault this problem?
L
10 REPLIES 10
rich912
Hi L,
There is good and bad news…
The VGN-FE31Z is not one of the models with an inherent Nvidia chip fault but given the beep code and as swapping memory has not solved the problem there is a possibility that either the GPU has failed or requires a reflow.
I can’t suggest any way forward apart from getting a repair company to investigate. You may want to try the following link – I have used their services in the past with good result.
http://www.tradelaptoprepair.co.uk/
Rich
Go n-éirí an bóthar leat
