cancel
Showing results for
Search instead for
Did you mean:
Question- How can I perform a System Recovery
profile.country.pt_PT.title
Victor99
Dear Community Members
I need to preform a System Recovery on a VAIO with original Windows 7. The system does not allow me to create Recovery disks or perform the System Recovery.
I have got some information about Windows Vista, but my system is Windows 7. Does anyone have some information about this problem.
Thanks
Victor
V57...
Hi Victor99,
Welcome to Club Vaio...
What is your Vaio model?
Have you change from Vista to Windows 7?
Take a look, here...
ftp://ftp.vaio-link.com/pub/Manuals/RecoTS/2010Q1_TRG_EN.pdf
Regards
1 REPLY 1
V57...
Hi Victor99,
Regards
