Charging the battery to 90%?
Canadianguy54
 I seen a feature on the A45 player to save some battery life on the player, anyone using it? How far should you let the battery drop down to?
Thanks
3 REPLIES 3
IamNic
Hi @Canadianguy54,
I use this feature and know that Sony offers a similar feature for their VAIO notebooks.
I only have heard good things about it, so I use it on my High-Res Player as well.
Regarding your second question:
I personally charge it at 15 to 10% and try to never let it drop below that.
I think this is also the recommended level for Li-Ion battery cells.
- Nic
Canadianguy54
Ok....thanks!
IamNic
Hello @Canadianguy54,
you are very welcome :upside_down:
- Nic
