My new headphones (WI-1000X) are really difficult to pair with my apple-products. I was able to connect to my iphone (after using the troubleshoot procedure) but not with ipad and macbook pro. Do I need to do the troubleshoot for every device I want to connect to? And how about the pairing for the iphone if I have to use the trouble shooting functionalities?
Hi Elinsen,
Welcome to the community.
I will pass this on to the team to look into and update this thread with any suggestions.
Thanks,
Pascale
Hi Elinsen,
I'm not sure which troubleshooting you had to do in order to get them to connect, however, I can see that connection with iPhone shouldn't be a problem as stated in the user guide in this link: https://bit.ly/2rfmbH4
I think the same concept goes with other Apple devices as long as they are compatible with the Bluetooth specifications of this device mentioned here: https://bit.ly/2Kt6Zhk
Hope this helps
Almou_10
There shouldn't have any issue but with Apple product, you often nee dto re-synch everytime you switch iDevices...
