MDR-RF810R Headphones
michaelw89
I have the above headphones. I'm looking to buy rechargeable batteries for them.
Would anybody know if I can still purchase the same ones that came with the headphones (battery ref:Ni-MH) or is there a similar battery that can enable the headphones to work?
Many thanks
Any AAA Ni-MH battery should do the trick as well - just pay attention that you insert them with the correct polarity.
Peter
1 REPLY 1
Peter
