Party chain SRS-X11 and SRS-XB40
profile.country.RO.title
gabi_dark
Hello!
I just buyed a SRS-XB40 and I asked the saller if I can connect with SRS-X11 and the answer was afirmative but when I arrived home I tried every method from the manuals, from the internet and that it came to my mind, also I called Sony support from my country and they asked me if I can return the produc becouse he dosen't know how to connect these two.
Has anyone tried something similar ?
Tags (5)
3 REPLIES 3
Anonymous
Not applicable
Hi there,
I will look into this, and get back to you.
Best wises,
M
Sean_Mc
Moderator
Hi Gabi,
You can find more details on how to pair your devices here.
Hope this helps!
Cheers,
Sean Mc
gabi_dark
Thanks for the reply but I can't find a method to connect X11 with XB40 there.
