Sony WI-C100 headphones
Rhino3957
I have bought a set of SONY WI-C100 headphones. However, there is no charging cable or anything similar in the box. So, how do I charge them when the initial charge runs out?
Thanks.
1 REPLY 1
jumpsuit
Hi @Rhino3957  and welcome to the Community :slight_smile:
You need a USB Type-C cable to charge the headset.
You can use it with a USB AC adaptor or a PC for charging.
Here are the charging instructions.
