I want to give some feedback on the Sound Connect app, but cannot find a way to do this other than on the Apple App Store, which I don't feel like is very community-based. This is for the Sony Sound Connect app on the Apple App Store, with my iPhone 16.
Can the app add widget features so that you can create short cuts to change the listening mode? Theoretically it would be good to be able to bind it to the action button on the recent iPhone models.
I feel like this would be quite a standard change to make as most apps nowadays have some sort of widget feature built in, but this would actually create a practical benefit since the Control Centre won't support this - presumably Apple insist on this so that they can keep the monopoly on their ecosystem, which is fine.
I hope that this can be considered soon.
Many thanks in advance.
