Usb Connection not Working
s26rech
Hi all, I just bought a new sony car radio ( dsx-a210ui ) that supports usb connection through Android Open Accessory 2.0. Reading the description it says that every android device with Android 4.1 or above should work.
For some reason when connecting my G4 it keeps saying "reading" without actually connecting. Am I loosing something?
I already tried to reboot both the car and the phone without any results.
I am sorry if this isn't the correct section but I couldn't find a radio forum section.
5 REPLIES 5
Pascale_F
Moderator
Hi s26rech,
Welcome to the community.
I'll see if i can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Almou_10
Specialist
Hi s26rech,
I'm not sure about this, but I think it might be related to the settings on  the phone. I'd recommend trying to connect another phone and check the results, also try to contact the manufacturer of the phone to see if there is a certain option in the settings that needs to be changed.
Cheers,
Almou_10
s26rech
I already tried to check any possible phone setting, I'll try to contact the LG support but I don't think they will help me anyway...
s26rech
Well any help is useful for me ^^
Almou_10
Specialist
Hi s26rech,
I'd say that trying to connect a different phone of a different brand would help you in this situation a lot, as this will direct the search either in the media receiver's settings or the phone's settings.
Cheers,
Almou_10
