WH-1000XM2 default volume setting
els76uk
Anyone know if it's possible for my WH-1000XM2 headphones to remember the last volume I used them at? I always turn them up full, and then use the volume on my computer or phone; but when I turn them back on again later, they return to low volume.
Thanks!
2 REPLIES 2
Pascale_F
Moderator
Hi els76uk,
Welcome to the community.
I'll see if i can track down an answer for you. Someone else in the community might have an idea in the meantime.
Thanks,
Pascale
Almou_10
Specialist
Hi els76uk,
I have these headphones and I can see the volume of the headphones is always on max whenever I connect them to my phone as I always keep the volume to max.
Do you mean the volume of the headphones or the volume of media player on the device connected?
Also, you can try to reset the headphones and see how this will work: https://bit.ly/2EW23xQ.
Hope this helps,
Almou_10
