What is the Difference between AVLS and Dynamic Normalizer?
Canadianguy54
Like the question says....
Thanks
1 REPLY 1
Sean_Mc
Moderator
Hi there,
The AVLS (Automatic Volume Limiter System) function allows you to listen to the sound at a moderate volume level when using headphones.  The AVLS function limits the maximum volume to prevent auditory issues or distraction and also to maintain a moderate volume level.
With Dynamic Normalizer, you can reduce the volume level between songs. With this setting, when listening to album songs in the shuffle play mode, the volume level between songs is moderated to minimize differences in their recording levels.
Best wishes,
Sean Mc
