Battery issue
RaviBajiya
Battery issue
Battery drain too fast..any solution
5 REPLIES 5
gregoryopera
What you have a look in the "battery" settings (Settings-->Battery), @RaviBajiya, what does it show has been using the battery the most?
RaviBajiya
Sir,I using Xperia x dual phone and my phone Android version is 7.1.1 . My Xperia x is not long lasting..when I using that phone so it's battery life ending in 5 to 6 only.. in time my phone in warranty also...so give me any solution..
gregoryopera
Hi @RaviBajiya,
If you have a look under "Battery Usage" (Settings-->Device-->Battery-->Battery level and estimated battery time), what does it say under "Use since last full charge" has been draining your battery?
Please post the information shown here, or post a screenshot.
dineshwaran
check the battery usage of every apps. I too experienced the problem.
If a specific appa consumes a lot of battery.
then try to do something in changing that permission of that particular app. some battery consumes battery for camera even without using the camera.
profile.country.PH.title
MarlonUk1
Aside from the suggestions given. take note that most battery draining apps are fairly obvious like social media apps. (messenger, FB etc)
you can compare you battery longevity with and without these apps.
