as far as I know, the default keyboard in X Compact is Swiftkey. there's no option to change Swiftkey's sounds, just the volume of them. if you think it should be something that should be changed, you can contact Swiftkey support and suggest it to them. you can also download another keyboard from Play Store, perhaps some of them allow you to change sounds.
